glow plug controller
83 chevy diesel
ky
the glow plug controller on my husbands 83 chevy snapped while trying to change it out. The bottom piece is still screwed in. How can i get it out without messing anything up on the motor?
I believe there are 2 bolts holding it in place, are both removed? A picture posted here will let us see what's happening
Will is talking about the blocker plate the old style controller threads into. The entire plate comes off with 2 bolts.
In fact the best cure is to leave the non-leaking busted "plug" alone and upgrade to the 1988 or 1993 newer style controller. The 1993 units are completely self contained where the 1988 has a separate switch on the rear of the passenger head for a temp cut out. A complete upgrade is self limiting glow plugs and an over ride switch for longer glow times.
Thank yall. I found it this morning and we got everything removed and put back together. The truck now has a new controller and relay and now the glow plugs won't even click when the key is turned over. What do I do now? Please help!
You need to put a test light on the glow plug solenoid and check for the main contact power in and out. If you get power in, but not out to the 8 leads, check control power in. Make sure it is getting a good ground.
Need major help!
