fuel upgrade and noticed hp/tq
93chevydiesel
Virginia beach
so i have the 93 6.5 with the GM3 turbo. i have turbomaster on the gm3 and im looking at doing a set of fuel injectors and i was woundering if i would notice anything out of the feed the beast upgrade. ive been looking around for people who have done it. a buddy of mine has a ATT and the feed the beast on his 6.2/6.5 hybrid he said he recommends it.
Not sure if there is a kit for 3/8 IP inlet BUT you can get one from a stanadyne shop.
IMO it allows for easier flow of fuel and allows for more volume into the IP.
Make sure the lift pump is good with all of the relay mods and even an upgraded pump possibly. Walbro units are nice.
Hi, I think that you have a mechanical pump in this 93 (not specified in your sig). Yes, the FTB or free-flow mod will help, it removes one bottle-neck The IP inlet housing should also be drilled, or a new one can be ordered from Stanadyne (Ford IDI's used housing with larger inlet). This completes the mod for the mechanical IP's as the ID of the passage in the housing is about .180". We have drilled them out to .250", which is the same ID of the larger fitting we used. The info for the Ford style housing can be found in Mike's thread for his Optimizer/DB4 build (a recent thread in 6.5L section).
