BBB82
Here it is I have a 1982 k5 blazer non -milt, all power opts, had AKA red block 6.2 in it now it was replaced with a 1986 6.2 block 40 over, 6.5 heads, GM8 setup with heath diesel turbo master, with that my mech pump on the block was out of the question still have the primary fuel filter on the pass side firer wall no secondary with 6.5 intake setup, also have kennedy diesel Duramax lift pump with control harness. Now for the hard part:
1. But the lift pump before or after primary filter?
2. Get a secondary 6.5 HO fuel filter setup from walking J or not need secondary filter?:hihi:
