I just installed
the AirDogII DF-165 (joy starts on post 156).
Return Line is included in the kit along with an adaptor at fuel filler neck (Some assembly required).
An electrical harness is also included in the kit so no need to DIY that one. You could splice in to the OPS circuit at the LP but another member here, Jrocket01, is seeing electrical issues (lights flickering etc) when high demands are placed on his AirDog 100gph unit.
Fuel Line lengths will have to be adjusted according to your mounting location. But, there is plenty of material to work with so one can mount it just about anywhere except a trailer and make the runs work.
D-Max installation manual available on the AirDog web site for download so you can see what's included and get an idea of what you're up against.
IMHO, Unless you plan on some very hard driving and feel you need the increased fuel demands, pickup the Walbro and save the difference over the $670 for the AD-165. If you're in a good place and are one who enjoys discovery, then by all means, go for it.
With my Walbro, I also purchased the Wix Pre-LP filter set up too. For power, one just nips the connector off the old LP and splices it on to the Walbro. Same thing could be done with the AirDog except for the issue mentioned already.
