I have change my fuel pump relay and the fuel pump is still not working correctly. If I by pass the relay the pump works great. I have check for good flow and everything looks to be good when I bypass the relay. I been given the impression that I should be able to hear the pump while I'm waiting fo the glow plugs to warm up, this is not the case. I have checked the voltage at the pump with the truck running and there is 14 volts at the plug. With the Key on there is no voltage at the plug.
Does anybody have any I deas I can try to fix this problem??
