Hate 2 ask but do u mean a inline fuse when u say relay? Since u r n alaska and have all that diesel experience could u give me some info on starting ur 6.5? Lets say describe 50 degree start, 40 degree start, 30 degree start please. I just got my my 6.2 and it starts amazingly easy but I am in NC and morning temps are 70 to high 80 and soon will b even higher! I want to b able to compare somewhat as the fall approaches and have ur temp sound and number glow cycles and say cranking seconds before ignition. My 6.2 is quick, I do mean quick to start on diesel like rump and maybe half another rump and she is gone! It starts faster than my Mustang! As I increase the wvo in the blend I will learn how it sounds and feels. I have my fuel pressure gauge and this weekend I intend to install it and the injection AKA coffee cup resisitance heaters on the lines and then I want to watch the fuel pressure for a while to analyze it and then change oil and change the fuel filter and watch the fuel pressure on diesel with a clean filter to get a feel for it and then put in the extra spin on fuel filter and the pre LP filter and again watch it a while and FINALLY start a gradual introduction of my wvo blend. I did it this way with the Mercedes and was able to switch a little @ a time and easily identify installation problems by how she ran and since I only made one change @ a time it was easy to find and fix the problems and believe me there were problems! LOL What a time with air leaks and trapped air! Touch these old lines and parts that have gaskets etc that r dried out and u gonna cause issues. What about my filter system I really want 2 use a 2 micron spin on filter, a really big one to help with flow. Do u think my electric lift pump can push thru it and still get the fuel pressure the IP needs? Thanks a bunch 4 ur input, my truck has 294000 miles on it, any idea how I can tell if the engine has that many miles on it? Its scary how good it runs and drives, I can tell the IP has been replaced or rebuilt and the injection lines have been messed with so I assume it has had the injectors changed. I got it from a guy who got it from another guy and neither one drove it any cause it had a unidentifyable antifreeze leak and they both figured blown head gaskets or cracked head or block etc and they couldnt fix it so sold it. I bought it figuring I could maybe fix and find the leak and even if it ran a while I could experiment with wvo. It barely sipped antifreeze but it did sip some! LOL Gave up finding the leak and hooked the gooseneck horse trailer with living quarters with 3 horses in it and headed to the foothills of NC with it in drive not overdrive @ 3000 rpms and after 50 miles I found the leak! Never been so happy to stop and see coolant streaming frum under the front bumper, I blew the hole big enough to find allright. Got it home and the radiator is now replaced with a nice new one and she dont sip coolant anymore so hopefully I have a very good truck. Can u start ur 6.5 @ say 20 degrees without plugging it in? Wow I talk a lot, sorry and thanks again 4 ur help. If I can get this engine to work it will help me a lot with my limited income and getiing to go camping with the horses on weekend trailrides, my old 454 1985 dually got 7mpg and I couldnt go anywhere.
