gahammerle
Saved by God's grace
I need to replace the line that runs from lift pump to fuel manager. Was just going to run rubber line, but with the tight space, I'd feel better replacing with factory type lines. Anyone know part numbers and where to get them? I'm going to replace both the feed and return lines - return is actually more rusted than the feed - I suspect the feed line has been replaced once before.
