Wrecker
The Oil Geek
I'll address cetane first.
Diesel fuels are classified 1D, 2D, and 4D. Low speed, stationary units use 4D fuels. 4D fuel is not appropriate for most mobile equipment. On-highway and mobile equipment use 1D and 2D fuels. High speed diesel engines use either 1D or 2D fuels. Important characteristics of diesel fuels are its viscosity, pour point, and cetane number. The primary differences between 1D and 2D fuel are the pour point and the viscosity. As you may know, pour point is the lowest temperature at which a liquid will flow, and viscosity is the resistance of a liquid to flow. A 1D fuel is designed for cold weather operation; thus, it is less viscous and has a lower pour point. A 2D fuel is used in warmer weather because it has a higher viscosity and pour point. The higher viscosity provides better lubrication qualities for the moving parts of the fuel injection system. Because 2D fuels contain more Btu's (British thermal units - the amount of heat necessary to raise one (1) pound of water one (1) degree fahrenheit) per gallon, they are able to deliver more power per gallon. This is critical to diesel engine fuel economy. The higher the Btu rating a diesel fuel has, the greater power yield per gallon; thus, higher mpg will result. Cetane rating is the diesel equivalent to gasoline's octane rating. Unlike an octane rating, which rates gasoline's resistance to spontaneous ignition, the cetane rating number (usually 40 to 55 for medium to high speed engines) notes the relative ease with which diesel fuel ignites. The higher the cetane number, the easier the fuel ignites; the higher the octane number, the more resistant the fuel is to ignition. Each manufacturer usually specifies a minimum or maximum cetane rating and the suggested operating temperature for 1D and 2D fuels. A given fuel may meet 1D or 2D specifications, but if the Btu rating is too low, then decreased fuel mpg will result.
Cetane number should not be considered alone when evaluating diesel fuel quality. API gravity, BTU content, distillation range, sulfur content, stability and flash point are all very important. In colder weather, cloud point and low temperature filter plugging point may be critical factors.
Diesel fuels with cetane number lower than minimum engine requirements can cause rough engine operation. They are more difficult to start, expecially in cold weather or at high altitudes, and they accelerate lubricating oil sludge formation. Many low cetane fuels increase engine deposits resulting in more smoke, increased exhaust emissions and greater engine wear.
Increasing the cetane number alone is not a fix for poor quality fuel. Additionally, increasing the cetane number beyond the engine's requirements will not increase performance. However, the cetane number of diesel fuel is not always consistent and you may desire to use a cetane improver to ensure full performance of your engine. If such an additive is to be used, it must not contain alcohol or other water emulsifiers (per GM).
For those of you running aftermarket or custom tunes, it is difficult to say what your minimum cetane requirement is, it may take some trial and error.
More on (Moron
) the other stuff later, I've almost bored myself to tears, I feel bad for you guys reading this.
More on (Moron
