Huge difference with winter blend fuel and what you run in AZ, not to mention the air temps. These trucks will stumble, bog, and throw a code or 2 instantly (and go into limp) if you nail it when the intake temp is +10* or lower.only severely contaminated fuel caused me to bog, reduced power DIC / low fuel rail pressure code, and require an early filter change.
Mike, you really need to change something. That is not a good looking filter after so few miles. I run either BP or Mobil fuel and add Power Service to each tank. White bottle in the winter and gray in the summer. He are pictures of my last fuel filter. It has 10K on it and I average 17.5 MPG.
The WIF sensor doesn't do anything until you have enough in there to stall the motor anyhow.I wonder where the water's coming from. The wire on my WIF sensor is broken at the base, and I'll be damned if I'm going to pay $70-something for a new one. Unfortunately, it's too short to solder.
