EraserX33
Hello all,
I tried searching for this information but was unsuccessful. I am not sure if there is a post on it and if so just send me that way if anyone can.
Issue is with my ABS system. I need to change the wheel speed sensors for my front wheels. I am not sure how to do this. From what I can tell it looks like I am going to have to pull the rotor to get to them and it looks like it is more involved than just removing the brake caliper and sliding the rotor off. Is there a post or some instructions for this sitting somewhere? Can someone give me a quick guide on what to do (preferably in 3rd grade English) on what is involved and how? I truly would appreciate it.
Also… while I am in there, truck has 110k miles on it. I have never touched the bearings. Are they sealed, a hub unit that just gets swapped out, or can I clean pack and adjust? I need to get the rotors turned while I am doing this as I had a pad score one of my rotors last spring and I just replaced the pads once I seen that the rotors would be a lot of work to be removed.
Anyway, I sure would appreciate some guidance on this. Thanks ahead for all.
