iamdave0887
Here Comes Chaos.....
Do yourselves a favor and check your frames around the front body mount steel on both sides of the vehicle. In between the two welded "perches" that make up the vertical sides of the body mount support I noticed a large amount of scale on the passenger side of the frame up next to the top body mount support seam today when doing some routine maintenance. A few taps with the extension i was using to tighten the exhaust crossover bolts revealed a hole a little smaller than a dime.
I painted that entire area on both sides with Eastwood Rust Encapsulator after knocking the remains of the scale/loose rust off, fearing that i'd find more holes. I pray it doesn't get worse, but only time will tell.
By the looks of things and considering there was another factory "pre-drilled" hole right next to the hole i made with the extension i believe that the hole i found today was a factory hole that filled up with road "crap" and rusted out a bit.
I'll be keeping an eye on those areas in the future that's for sure.
