mgray
Changing the oil, and figured I should finally clean the last of my grounds. With a chain of extensions and a u joint I got the bottom frame bolt off.
Now for the engine bolt. I removed the top nut holding the tranny filler tube bracket and removed the bracket. Then tried to remove the nut on top of the ground connection and noticed the whole bolt twisting! At the same time, all the crud around the base of the bolt started to get saturated and I noticed that fluid is seeping out of the bottom of the bolt. Seeing as this is in the head, I'm kinda worried. Is this normal?
Also how do I remove the nuts without twisting the whole bolt?
Thanks
Thanks
