bearskevin
Ok I probably should not have done so much right away but I guess I "assumed" that their wont be much of a difference between gas and diesel. you know give it air, fuel and fire it runs. key word I learned for a diesel is "must" have the right amount of air fuel and fire.....
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). ____cranks (destroying batteries LOL) but wont fire________________________
- Year: __1984____
- Truck model and class (ie: c2500) ____gmc jimmy _____
- Automatic or Standard ____auto______ (new rebult tranny has yet to fire with it in)
- Mileage: (indicate miles or km) ___99,780______(odometer doesn't go past 99,000 so no clue....)
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _____turbo 6.2L no EGR_________
- Ambient outside temp: (indicate *C or *F) _____68' southern california_____
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ___#2______(3/4 of fuel tank full)
- What fuel additives are you using? _____none______ ( no smog junk added or needed either)
- Where are you located? ______Rossmoor_______ northern orange county near long beach California
- Air filter ___usable______ came with purchase
- Fuel filter ____new _____changed 2 weeks ago
- CDR Valve? ___new______ changed 2 weeks ago
- Coolant – last flushed/replaced at _____new________ changed 2 weeks ago
- Oil – synthetic/regular, changed at ____new_______ changed 2 weeks ago
- Batteries – state of charge, (matched set) replaced at ____1 new optima red top (bought yesterday) 1 interstate or champion_________ (champion and interstate are original from vehicle purchase before a starter welded itself to run and burned up)
- Battery cables and grounds (removed, cleaned and tightened): _____new cables_________ week old
- Glow Plugs - how many miles on them? ____0_____ What type? _____________
- Injectors - last changed at ______2 new BWD _________ changed week ago
- What were you doing when it happened? ______just purchased vehicle drove it for a week knowing bad tranny, got rebuilt tranny installed, changed the following during same event:
fuel filter, valve cover gasket, intake manifold gasket, oil pan & gasket, oil filter, flush radiator new coolant, new glow plugs, new starter ( 28Mt gear reduction)________
- How was the truck running fine before this problem appeared? ____good but sounded like might have a miss, also leaked oil (see above list for corrected actions) occasionally would not start (this was due to a bad starter solenoid (see starter fire above) ______
- Has this problem ever happened before? _________never air locked, after all parts were changed after starter fire was leaking fuel at injectors (2) and at return lines (2 also)______________
- Describe any related factors that might be part of the problem. ____time line__________
purchased a 6.2l turbo diesel a month ago> drove around waiting for new tranny buying an assortment of fluids, gaskets and glow plugs> 2 weeks I guess go buy> took a week to change the following ( had to go to work also) Tranny, oil pan, front leaf springs changed to a lift, rear leaf springs on lift blocks ( for now), oil dipstick tube, valve cover gasket, intake manifold gasket, glow plugs flushed radiator, got fluids put into it and try to start after priming the fuel system used the air compressor method and bleed at fuel filter.......yup you guesses it starter solenoid locked and caused fire... replaced starter> leaking at injectors and fuel return lines on injectors now.> replaced to the 2 injectors (fixed injector leak) got the correct return lines for each injector (fixed injector return line leaks).> go to prime and crank and it wont. chased it down to fuel is in filter/ fuel is in the Injection pump (even found a hole in the steel line from filter to injection pump patched it) fuel is not getting to injectors now (insert curse words when found this out here )
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __n__ And? ____will be soon____
Diagnostics:
1] Starting:
1a] Does the engine start? ___y______
1b] Does the engine crank over? ____n____
1c] Are your batteries fully charged? ____optima yes champion no_____
1d] Have you removed, cleaned, and tightened all battery connections? __y______
1e] Does your Wait to Start light come on for a time? How long? ____manual glow plug switch_____
1f] Does your glow plug light come on? ____y_____ For how long? ____forever haha_____
1g] Do you see smoke from the exhaust while cranking? What color? ____nope____
1h] Does the Service Engine Light Glow during Start/bulb check? ___nope_____
2a] Can you hear your lift pump working? _____mechanical cant hear it_______
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ___????______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ____need to check but IP is full of fuel_______
2d] Loosen an injector line and crank the engine - does fuel come out? ___no______
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _____yes______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ____on pump _______
3b] Condition of Extension harness (if used) Vendor or Homemade? ____na_____
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ___all cleaned______
3d] PMD Make: ___________
3e] PMD Age: _____________
4] Stalling Issues
4a] Do you experience stalling only when hot? _____n_______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) __n____
4c] Does pouring cool water over the IP seem to help with restarting? ____n_____
4d] Is stalling momentary (engine recovers)? ____n_____
4e] Does SES light come on when engine hiccups? ____n_____
4f] Does cruise control quit working when engine hiccups? _____n______
4g] Does re-starting seem to reset engine, restoring cruise and power? ____n_____
4h] Changes to dash lights or instruments during stalling events? ____n_______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _n______
5b] Any bubbles or oil film in coolant overflow tank? __empty_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____n_____
5d] Excessive white smoke from exhaust on cold start? ____n_____
5e] Excessive black smoke from exhaust under hard acceleration? ____n______
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? _____turbo boost exhaust temp______
6b] Maximum boost under load? _____10_______
6c] Have you added a performance PCM (reflash) or Chip? ______n________
6d] Have you changed exhaust / downpipe / crossover? ________n________
6e] Wastegate – mechanical or vacuum (OEM)? _______n_______
7a] Single or dual thermostats? ______n______
7b] Have you replaced them lately? Manufacturer of replacements? ____n_____
7c] Have you pulled and cleaned Radiator and coolers lately? _____n_______
7d] Have you replaced the fan clutch? Manufacturer of replacement? _____n___
7e] (winter) Have you tested your antifreeze? Good to what temp? ____n______
7f] (winter) Are you using a winter grille cover? ____n_______
_____________I have checked the fuel shut off solenoid I hear an electrical click is there supposed to be a mechanical click ____________________ lets start with all of this
- Year: __1984____
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
