swany211501
1- I cut the upper intake out the other day, cleaned all the soot out of it, put it all back together, as well, blocked my EGR with gaskets and a plate. When I opened it up, it was oily, really oily. How much residue should be in the intake? My turbo inlet is always wet as well as the intake hose. Is this normal? Is the CDR not functioning like it should be?
2- I got a bad bunch of fuel, loaded with water. My fault. Anyways, I was going to drop the tank because I had always planned on changing my supply and return lines trying to stop the air bubble problem I have. What size is the return line going to the tank. Is it necessary to change it?
3- Does anyone know what thread size the FFM bolts are? I was thinking of using all-thread rod and double nut the FFM so it was higher than the intake so I could eliminate the bends in the fuel line. I have a bunch of brass on the front for FTB and a pressure gauge and I was concerned about clearance under the intake. (Suggestions for moving it are always welcome)
Thanks for the help
Frank
Thanks for the help
Frank
