Favourite rims - Post them.
Thanks Jeff.
Sorry Will - wasn't even paying attention to that. 1500 cc as in a half ton crew cab? If so, no 8 lug rims for you. haha
Good luck man - you'll find something that makes her stand out!
Thanks Jeff.
If they would make something identical to that in a 6 bolt, I would be real happy. A truck upgrade is not in my future, unless the lotto helps out.
They're not H2s but how about it's little brother the H3?
Oh yeah, forgot about that. They are six lug but the Colorado/Canyon bolt pattern. Idk if it's the same pattern as FS trucks or not.
The H3 rim is a 16x7.5. 6 x 5.5 bolt pattern with a 38mm offset.
The Silverado rims are also 6 x 5.5 bolt pattern with most having a 31mm offset.
If you were to use these wheels, the inside of the rim would be 13mm or 1/2 inch closer to the inside of the vehicle... So they should work. I have scene the H3 rims on a Tahoe before and it looked pretty good.
Could always get a wheel spacer on the hub to help get that h3 rim out a little farther. I think it would look pretty sweet if you went with the h3's. Especially if your looking for 6 lug wheels.
What kind of tires you looking at? Meat or... not so much...?
