CORVAIRWILD
My '84 6.2 K20 Sub won't drop from fast idle. So 5 years ago, I disconnected the solenoid. I've just chngd the water pump, so now's a good time to put in a new switch. But what is it called/part number?
I looked around, and almost found what I think I need...
http://www.gm-diesel.com/vbull/non-.../22051-6-2-cold-start-solenoid-fast-idle.html
The one behind the RH ex manifold has 2 prongs, and I think that's the correct one. Maybe I'm also running cold advance all the time if the fast idle won't drop by itself? The sol de-energizes when I pull the green wire.
