matuva
Tropical 6.5er
Finally. I won't try to tell you fairy tales : I promised I will post a "how to" which will help you to mod these euro headlights so they will perfectly fit.
I promised, but wasn't able to do in time, and I apologize for that, whatever were my reasons (lazy, dog days, lack of time...)
Once again I apologize guys.
The problem lays here : the retainer on the top/middle of headlight is too long, 3/8" too long, and it pushes the all block "outside".
Solution so is to shorten it.
Here are pics with comments, and I hope they will helpful and clear enough.
use a 1.2" long flat screw, re-screw the holder
Once the mod done, re-mount the adjusters, back plate, adjust the all thing, and they should fit perfect. That works each time I did the mod.
Hope that helps.
Hope that helps.
