Ethanol vs Methanol Injection
chrisk1500
Hey Guys,
I have my pump on order for my WMI system.
Let's have a little discussion about the pros and cons of injecting an ethanol mist vs a methanol mist into an IDI diesel.
I have heard stories/facts about both fuels but would like to hear more opinions.
What fuel is better for engine longevity? Pre-ignition concerns? Negative impact when mixed with diesel?
Let 'er fly...
All I can add is in gassers meth. can only be a 5-10% conc. Where ethanol can be any conc. Leo
If your engine grenades, you can sit and drink ethanol while you're waiting for the tow truck... :)
Back in the day people used to fill the washer reservoir with alcohol and run the line into the cab. Could you see Chris doing this with the WMI?
Leo​
Leo​
Hate to admit it, Leo, but I had one of those... Got pulled over on Hwy 36 with a cooler full of coca-cola, on the way to a ball tournament in Stettler... he never did find the Rum. ):h
It really ticks the mounties off when they know what you're up to but can't find it.):h
*bump*
Anyone with any real information?
The pump is on its way and I want to start planning things out....
Golds to the rescue...:D
Does this help?
I recommend methanol (unless ethanol is more readily available AND there is an off chance that you might get thirsty):h)
Regards,
Ah.....my hero!
*slap*
I was told that methanol was more corrosive than ethanol....fact or fiction?
Ah.....my hero!
*slap*
You should be using 30R9 "fuel injection" rated hose in either case, so I have no greater concern about one over the other. You would probably also want to include a bit of upper cylinder lubricant (designed for use in methanol) in either one.
*bird*
Regards,
