Steve93mustanglx
Diesel fanatic!
Hey folks, having a number of electrical issues with the 'Burb. I have a heater blower motor that will not work using the switches on the console. Took it out today, wired direct to batt, works fine. I reinstalled, ran ground wire to chassis and it works that way, too. OK, so I have a ground problem. Makes sense, I just replaced a fuel tank sending unit that still does not read correctly.
I cleaned the ground for the sending unit (no improvement), cleaned the PITA ground under the downpipe which has 2 ground straps to a common bolt (no improvement) and re-cleaned the batt terminals and various other under hood grounds.
What am I missing?
What am I missing?
