EGT drop with new exhaust
bighawg
Proud Rider of the Short Bus
Carnesville, Georgia
How much temperature drop can you expect with a 4" turbo back kit.
Mine run between 700 and 800 cruising at 55-60. Banks 6 gun on SL. It will get to 1500 in a hurry in hot weather when you start kicking it around.
My exhaust is stock but looking to upgrade this week.
You should see a 150-200 degree difference up top, you may not notice as much of a change in your cruising egt's.
With a downpipe and 4" turbo back (w/muffler) - I had a 100 or so degree drop towing 5K today. My air filter is filthy too, so I hope for improvement when I replace it this weekend.
You will see some drop.But surprisingly enough,it isn't as much as you would think.100-200 is about average I believe!
I'm hoping that it will drop some on the top end. Mine gets to 1500 pretty quick when I'm standing on it. Thanks guys for the input.
I saw 100 deg at cruise and over 200 near 1300 deg. at top. It is worth installing. I have heard a boost stick drops temps. also.
