eBay injectors
devildogadam
Yakima WA
Thinking of buying a set of marine injectors from diesel care and performance off of ebay. Wondering what you guys knew about them or if anyone had good or bad experiences with them.
I haven't dealt with them but believe their rep. isn't too good.
Badger Diesel has a fairy good rep. IIRC
3500_6.5. I see from your Sig you know the pop pressure they are set at. Did they let you know or did you have to test them yourself and could you pick the pressure.
Those are different ones. I do not know the pop pressure of the ones from DCP, although I didn't think to ask them either. The ones in my sig are from Unique Diesel, I got them when I had my pump built. I ran the DCP ones in my truck until then and then put them in my Suburban. The Suburban has gained a few mpg, but the injectors that were in it before were going bad.
