I have the 6 bolt clutch and bought the 2001 fan. It bolts up and lines up fine. You don't use the holes for the fan. There are 4 holes that are offset and just barely line up with the clutch. I found this out by accident and was going on a trip and needed the fan bad. I was even going to drill new holes to make it fit because sending it back or buying another clutch wasn't an option at the time. after spinning it around I noticed that it would bolt up and it doesn't hit the shroud and is in center and balanced. It's been on there for 3 months and no worries.
Thank you for the info guys. I did the research and here is the rules for the fan to clutch with 6 bolt configuration. '96 the clutch changed to the 4 bolt fan to clutch. Also, in '99.5, the 4 bolt clutch to water pump changed to the threaded shaft. Make sense everybody? Using the wrong holes, it can be done on the 6 bolt fan to clutch, but I don't like that. That's just IMO.
Someone with a 6 bolt fan to clutch has four options to switch to a duramax fan and 185 deg.F clutch assy for the lowest prices I could find. Remember there are discount codes on our site here for rock auto too:
1) Buy the 185 deg. F clutch and d-max fan assembly through Walt for $200
2) Use the wrong holes on the 2001 d-max fan blade w/ original clutch and adjust the bi-metal strip on the clutch to desired setting, rock auto fan only price $54.79; p/n 1580690.
3) Buy a stock or severe duty clutch for a '96 or later from anywhere and adjust the bi-metal strip. Rock auto price for stock '97 clutch $95.79; p/n154674. Hayden Clutch$142.79; p/n 2839. $54.79 for fan; p/n 1580690. Stock total $150.58. Hayden Total $197.58.
4) Junk yard clutch like i just did for 20 bucks, used the clutch bimetal spring adjusting link in the stickys, buy the d-max fan from rock auto with coupon code. Total cost, 75 bucks. :thumbsup:
I hope this really lets everyone know what they are up against for '95 and older. I hope it helps too!
NOTE: The Hayden Clutch engauges at 170 deg. F. That's a little low for me. I usually run at 185 deg. F. I don't want the fan running constantly. I set mine for 190. For info how to adjust the temp on your fan clutch, check the stickys.
http://www.thetruckstop.us/forum/showthread.php?t=12265
