mitchedo
There are two bolts through the intake manifold into each head that go into the water jackets. If I remove the intake manifold with a full cooling system, will coolant come out those holes? I don't want to make a mess, and I don't want to lose any brand new coolant.
I have a significant oil leak out the valve cover on the right side (of course it's the right side). It looks like I missed a spot with the sealant. At any rate, I have to pull the valve cover. :mad2:
I was getting so close to getting this thing on the road.
On the plus side, the engine runs much quieter than it did before, without any of that hint of knocking I heard before I tore it down. It seems to run much smoother too. Perhaps it's the balance job; perhaps it's the Fluidampr. ...maybe both.
