OrionThade
Would you mind sharing what you've got?  I'd like to do a diff between a stock tune and your tune.
Sent from my PG86100 using Tapatalk 2
Best way I found is to number the tune, then I take a scanner and run the truck watch where it smokes write it down make modifications and then re run the truck to see if the mod works. So far it is working for me, have about 25 hours total drive and desk time into this tune. Real time tuning makes it much quicker, pull over make changes drive on. don't like go back to my original tune start over get something good keep it next version then all over again. It is time consuming but I have found that the one tune fits all does not work. Most tunes I have looked at only modify the timing and fuel table. Only one guy has done more that I have seen. I was at 3500 rpm today and smooth as glass, sucked the restrictor indicator down on my k47 air box with a large filter, now what do I do.
Maybe when you get your truck sorted out you can loan the real time stuff to other tuners. I've had 50+ chips in my truck at this point, and I think my tune from a month ago was the best I had.
I have the trans settings in my definition file made by Rainstate. BUT I DON"T HAVE A clue what to do with them. Maybe talk with TheFermanator he knows his stuff about tuning, trust me.maybe someone could take the tune and add the auto trans settings if possible. I'd be interested to see how it runs in mine.
I would just take your file, compare it against the stock bin its based on, then duplicate the changes starting with an automatic bin, but I really don't have a clue what i'm doing. I was just happy to be able to burn the chips, I figured learning what I was doing would be the next step =)
So, could you upload your bin?
Not until I get it set up correctly and make sure there are no problems with it. Trying to see how it works on OBD 2 as well, I want to make sure there are absolutely no problems.
Made more adjustments today. Boost .2 tenths of a pound at 1293 rpm no shifting needed fifth gear no smoke under load. 110 MPH today and very little smoke 15.5 lbs boost through an intercooler set up this time. Getting close, fuel mileage is up considerably (Perceived not yet documented) and using third gear where I would have had to down shift to second before with the other tunes I had; definitely not tunes for the A-team Turbo. Also there is but loads of power, and man does the turbo spool fast, cruising now have 1.5 psi at 1850 to 1900, consistent, and I can burn 70 mm of fuel at below 1600 rpm and get very little smoke before it goes away. GO figure that tuning would be such a BIG BIG BIG variable, for properly setting up your truck. I have a sheet eating grin every-time I drive it now. Hats off to Thefermanator for putting me in the right direction. :agreed: and to Rainstate for the custom definition file. More things to adjust than the other definition files. :skep:
Hopefully, this will help sell the turbos. Personally, a hangup to upgrading the turbos is that the tunes are nearly as much as the turbo, and are really necessary to make the upgrade worthwhile. Streamlining the process with cheap tunes is a great way to sell hardware. What I'm curious about is how you are testing obd2 as well.
the agenda is not to present factual information in any manner, it is to present manufactured data set up to fail one product and sell another: one of the oldest marketing schemes in the business world, kind of like a taste test with people you know hate one taste and like yours.
