i have been running wvo mix for a few months but have decided it's not worth it, between fuel filter changes and being stranded, those days are over. think i have IP damage but i want to rule out anything else.
after it sits overnight, it will start pretty easy, just a few revolutions. after sitting 8 hours in the day, hard to start with a lot of cranking, priming with wd40, and will die when dropped in gear, then i will do it all again to start. if i rev it up before i drop in gear, it will keep running. rpm had slowed down to 4-500 so i idled it up, around 900, to keep it running. filter is new, pressure at 7 idle, 5-6 running. no sock. was running great last week, all it took was a short crank to start. i didn't even need to give it any pedal. LP is new. have maybe 30,000 miles on this IP.
have another IP, that i will increase case pressure/fuel delivery, that i can drop in but want to rule out any other suspects. any thoughts?
