- Staff
- #21
Perseverence (being a PITA) pays off! Good for you!
I was told they will only replace the injectors one time under the warranty and mine were done at 90K. Is this BS?
if you feel like ct.....
Well, the drama continues! Once the dealer saw the truck, it dawned on them that they said they wouldn't do the injectors, so they are backing out of it now. If anyone knows of a dealer that will stand up to this crap and do the work, I'll put it on my trailer and haul it with my brothers cummins about anywhere! Unreal!
I took mine to three different dealers...got new injectors...then had to fix it myself...
what is the reason given for bad i/p? and just an fyi, the injector warranty is at the dealer discretion. yes they are required to follow the service procedure, yada yada, but when you have a dedicated customer and if you put customer service first the injectors get done. once the job is done there is no way to verify what is written on the spec sheet, and 100% of the time the injectors are bad, and gm only wants to pay for 50% of the actual jobs under there bull crap policy.
i just replied to your efi question. okay, the pump is not likely the issue. monitor your balance rates using the efi live scan tool, and go from there. you can also use the bidirectional controls to ramp the fuel pressure yourself. see what it reaches.
bad injectors will cause low pressure. it is safe to say it may still be a bad cp3 but to diag it right we need to start with the obvious known issues with the lb7. i had 2 bad injectors and low rail pressure condition in my truck, we did the injectors first, then tackled the pressure problem. it ended up being the cp3 also.
