davo727
This ones my 92 C2500 parts truck, bought this from a kid for 1k.
He had put brand new heads on it and then it locked up the bottom end 2 weeks later.
It has a 599 block, havent pulled the pan off yet , it started raining as soon as I got the motor out. Has a good turbo and DB2-4911 pump.
Parts from this 8600lb gvw 8 lug truck that I will eventually swap to my gasser 93 C2500 7200lb 6 lug truck will be :
The NV4500 trans, the hydroboost brake sys, the 4.10 posi 14 bolt semi float rear, and the 8 lug front suspension and brakes.
The heads and hopefully if the block is good it will end up in the 92 Dually, but it will be a while as I need to move 35 miles north to my property and build a shop up there before any of these trucks get any real $ attention.
