Danville Turbos and Others
  • Thread starter Thread starter dieseldays
  • Start date Start date
D
dieseldays
Guest
ok. for a lbz what would bet the better option?
HTT Promax
Daniville charger??
Open to opinions
Well, I kinda feel Danvilles chargers are a little pricey for what you get. The cheetahs seem to be falling apart. I'm still searching for my charger at this point.:noidea:
if you want to keep the vvt function like I do then its a danville or a garret 37 something that just recently came out. if your not worried about keeping the vvt the sky is the limit for what to use. whats the main function of the truck? DD, race, or tow?
Are the Danville's in the same $$ range as the Cheatah's? I PM'd Mark and haven't heard back. Not that I can afford one right now. Just trying to narrow it down when I do.
I would go with HTT I know Pat has good luck with them.
I can't decide on my charger yet either so many options, my head spens sometimes.
I wouldn't worry about the VVT I will most likely do away with it, as a DD, Tow Pig, and weekedn warrior.
I think Danville's are a little cheaper.
Danville has two options now. The stage 1 is around $1800 now and comes with a diamond eye downpipe. The stage 2 is similar to the cheetah and in the same price range.
I have been pretty busy lately and haven't been able to keep up with the boards like I used to so I am wondering what you meant when you said the Cheetah turbo's seem to be falling apart. I am trying to decide between a Danville and a Cheetah to see which will be my next charger.
