Well... I finally found some time to install my latest turbo. I still need to fabricate a better air filter location. I am thinking of plumbing the filter inlet to behind the front bumper by the intake inlets. This turbo is a little smaller on the turbine than a HX turbo and the compressor is a little larger. This gives it fast spool and eliminates the "fall on it's face" the GM-8 does. I end up adding a external wastegate which is a little overkill. I may add a manual boost controller, so it will aid a tiny bit more of faster spool. So far EGT's are 400-475 at cruise @ 4psi, and the has very simular EGT characteristics to the GM-8.
