matuva
Tropical 6.5er
Yes; sometimes I think she is... It did appear suddenly.
This evening as i was cruising back home, I suddenly heard a knock growing stronger and stronger.
Back home, it was so strong that I was afraid I broke a valve or a rod.
She then smoke raw fuel...
I hooked my scanner (GMTDScantech) and found a DTC about calibration resistor error, and one about pedal position error.
I believe these codes have nothing to do with my problem. I change the settings on my chip, switching from towing tune to economy, no luck.
Then, using the injector balance feature, I disconnected the injectors one by one. As soon as I disconnected injector # 2, she stop knocking and
smoking. As soon as I release it, she knocks again and smoke raw fuel.
I took her for a drive with the scanner hooked and maintaining injector # 2 shut off, and she runs almost fine, no knock, no smoke.
I was 1st thinking about broken valve, but, if it is, she would knock at any time, with or without injector cut, no?
I'm not injection specialist, but it eems injector #2 has quit. What do you think?
