the 96 c2500 in my sig is having a strange problem. Under an abrupt accel, the truck cuts out fuel and dies. This only happens when I encourage it to, sometimes not(intermittent) So, the usual...
-batteries are ok, alt ok
-just replaced all main cable terminals and grounds, starter, engine grounds as well
-lift works, primes at ko-eo, new fuel pump relay
-fuel quality itself, always a reliable local co-op source
-basically all serviceable fuel system parts are new, and oem if possible
-IP age unknown, but I do not suspect the IP is the issue, ruled out
-no fuel leaks anywhere
-PMD newer
the only place I have not ventured into, the fuel tank. could a snotty fuel pickup sock be causing these problems? fuel cutting out? is my pickup tube rusted out?
it isn't until the lift draws a large volume all at once...then...no fuel
fuel level does not matter.
the only other issue is the weatherpack connectors under the hood have all suffered the effects of long term heat and are dry cracked. most missing clips and needing a zip tie(i know). so could hard accel/coupled with engine torqueing be causing my main engine harness to stretch and cause erradic signals? (optical sensor)
does anyone know where to buy these individual #pin weatherpaks? or should I source another harness from the "yard"?
anythoughts are appeciated.
-PMD newer
