I elected to install a 2.5" Warpspeed crossover when I installed the Diamondeye exhaust. See my thread on this project:
http://www.thetruckstop.us/forum/showthread.php?t=19218
My reasoning was as follows:
- 24% greater flow area than stock 2.125" pipe(4.91in2 vs 3.97in2), 1/4" diff in diameter makes a significant diff in area, less resistance to flow
- Smoother mandrel bent pipe, no wrinkles like stock pipe, less resistance to flow
- Single wall construction won't ever collapse and obstruct flow
- Gave me a chance to change donuts & Neverseize the fasteners.
The common theme to my exhaust upgrade was FLOW as in less resistance to FLOW: Larger pipes, smooth mandrell bent system, straight thru muffler, no cat converter. Seems to have worked, throttle is more responsive, EGTs are lower. True test will be in the summer when I tow heavier loads and the ambient temps are in the 100 degF region.
