Hydrauk
Hydrauk
Hello to all..
I am new at this site. If you read my posts I have been quite active since I joined. I have already learned alot. And hopefully helped some as well.
Ok..so today I cleaned the underside of my truck. I like to keep it grease and Oil free.
So after I finished using degreaser and a light pressure wash, I went to move the truck. Upon starting, I first off saw it cranked for a long time before it ran, way longer than it used too, and the "service engine soon" light came on. Not only that, but it sure seemed to be louder than it was. It sounded like my Cummings!!! Load diesel for sure!
I let it run for 20 mins and while running, I sprayed WD-40 on ALL electrical connections. It dried up nice. I moved it. Shut it down. Waited about 5-10 Minutes....again...it cranked a LONG time before it ran, and it was ratteling like a cummins. And the "service engine soon light" was still on.
Ok...So I disconnect the batteries...for about 20 Min. Re-connect...and tried to re-start...nothing changed.
Cold, Frustrated, and tired..I drove to Autozone...Hec..they have a scanner...right? Okay so they guy hooks it up...I get code for "Bad Crank Sensor". Makes sense...I just washed the underside of Engine areas.
Drive back home, It drove/Ran like shit. Hope that I could just use WD-40 and clear out moister on Crank Sensor, Well...upon further inspection...the wires going into the sensor where frayed and just plain ole' broken/Damaged. Real bad connection. Made sense!
Questions:
A. Crank Sensor plays a big part of the engine...So am I hearing things..or does the truck now sound like a rattaling Cummins...it really rattles loud...WHY??
B. Seems like the power..and drivability have gone WAY down hill.
C. This bad "crank sensor" seemed to be stuck in the block, I removed the hold down screw....It's not comming out...any suggestions? Common probelm?
So...YES it's bad...I now have to wait til Monday, to resolve the issue. Any Input or Ideas would be welcomed. I have searched the site and found out SOME information about the "Crank Sensor" any other info would be great!
:mad2:
Iam going to have some beers and get some sleep. Thanks in advance for your time.
Cheers!!!
David
Questions:
:mad2:
Cheers!!!
David
