I still would suspect the water pump for the above reasons.
water wetter - I use it in everything. Can't say for 100% sure that it helps but it doesn't hurt.
A new condenser helped me along with a new radiator, high output water pump, 9 blade fan, 180 t-stat, and Kennedy clutch. Replacing the condenser has the fan running less but many fins were bent by a PO pressure washer mess…
You would not see the amount of coolant that it takes to ruin an engine in the oil. You have to sample it. Sample kits are cheap and so are the sample results.
