I had headgaskets replaced in Oct 07.
About 2 weeks ago I noticed what I believe is coolant under the truck ONLY in the morning before I started the engine. After the engine warmed up there was no leaking or sign of it anywhere. I looked under the engine and trans and the only sign of leak was on the flat section of the trans and engine bolt up face. It was in the flat section where the weep hole is.
The fluid appeared by feel to be coolant but the color is closer to trans fluid. I felt of both fluids for samples and it really feels more like coolant.
It kept getting worse and I was thinking maybe a cracked head or the headgasket again. Then I began to think maybe because of no sign anywhere except the eng and trans bolt up face that possibly the rear eng freeze plug or plugs are leaking. If it is not that I have no clue what it is.
I took the truck into the dealer this afternoon and they could not see any evidence either. They kept it overnight to take a look at it in the morning.
This is really getting frustrating by not being able to see where the fluid is coming from.
UPDATE 1/14/09
Dealer called and said that they had no sign of a leak. I asked if they kept it in the shop and the shop was warm and it was. I told them to leave it outside since it will be cold tonight and see what they get.
UPDATE 1/14/09
