coolant leak
crash
nc
Ive got an 06 3500 chevy and ive got an coolant leak and its running of the back of the driver side of the motor and ive pressureized the system and found a few small leaks and fixed them but whats down in the vally that has coolant running in it?
its probuly coming from the 5/8's rubber hose on the egr cooler in the eng valley,thats were my 06' lbz leaked,,,i also had a coolent leak on the drivers side lower eng side by the oil filter,it was the eng oil cooler gasket at the block
ok its coming from the driver side running off the back of the motor
I can't remember if it's a rubber hose running to the turbo or not... relatively certain it isn't. You can see it down in the valley once you unplug the big bale connector and take the turbo inlet off. There's a pipe that runs back from the metal pipe where the rad hose connects coming off the driver's side of the engine IIRC.
Check the oil cooler to see if that might be leaking coolant also.
