There is easily a good 4"+ between the WMS of a single wheel truck vs the one used on a dually truck. I don't know of any wheel studs that would reach that far, let alone still have threads to grab the wheels and have full engagement of the lug nut. Not to mention with that much spacing there would be a huge amount of lateral force applied to the wheel studs. 8 lugs or not that will stress the studs and potentially snap them off.
There is a chance you may be able to get a set of hubs off a dually truck and replace the SRW style hubs with those. Can't guarantee that will work though, it may be worth a shot if you can get ahold of some for cheap. IF that doesn't work you may end up needed the whole front IFS assembly to make this whole thing work. Is it a 4x4 or a 4x2?
