Edzzed
Soak it in coke.
hey thanks.For the Al cast parts w/ texture like the intake hat/manifold, turbo comp housing, etc., the acid based wheel cleaners (intended for cast Al wheels with all rough/textured surfaces) will disolve the oxidized, dull Al off the outside & brighten things up. They'll also somewhat etc. machined smooth surfaces which usually looks worse.
Glass beading is the easiest & produces the "newly cast" Al look very consistently. Of course the parts will again slowly oxidize just as they did from when the vehicle was new.
If have an adequate air compressor & a little space, the cheapy Harbor Freight blast cab that goes for ~$200 on sale is a decent workable cabinet. Once you get the capability to abrasive blast & power coat old parts, you get hooked. I think Barry's been working the heck out of a budget blast cab he got a while back.
Just don't snort it afterwards...:rofl:Soak it in coke.
You're busted,it doesnt work worth a Fiddlers F'ckrrr
:h
hey thanks.
where would i be able to get that stuff?
No harbor freight up here but i been thinking of getting a blaster.
Thanks you all,i checked it out,got some on order,will be here tomorow.
