Your call Justin, :idea: should stacks adjust the volume knob...):h
:smilielol5:Well I uhhh... I had the dimmer nob turned all the way dim and had the PA/CB switch on PA so it looked as if it wasn't working :crazy:
QUOTE=stacks04;50210]mine isn't working either. it is the handheld cobra unit. it turns on and powers up fine. the issue is once it is on i hear nothing out of it. even if i turn the squelch all the way down to find the best spot it never gets static. just like dead air. then it will work then stop. pain in the arse.
Stacks, check your coax for shorts/opens. If your coax is shorting out, you'll get the exact condition you describe. I had the cobra like you describe in a jeep...couldn't stand it personally. I couldn't hear a damn thing on it so I got a cobra 19 and haven't looked back.
