lodmax
ok drive through ill. alot whats up with all the bugs. need help debugging my ride . can you help ?????
I have read that a spray bottle of water and a dryer sheet is the ticket for getting bugs off. Lightly spray the water on then rub off the bugs with the dryer sheet.
DRYER SHEETS?? The only thing I've ever used those for is getting rid of smoke smell and doing laundry! Never thought to use them on bugs. I just use a 4000PSI Heated pressure washer. They don't stand a chance against that one!
