Pillow
Recruit
In my effort to clean up all the grounds on the Burb... One ended up snapping off. The one in issue is the one that hides under the coolant line entrance to the heater core. It is pretty well hidden unless you know what you are looking for.
Here is a pic that TD posted on other Place:
http://www.dieselplace.com/forum/attachment.php?attachmentid=47719&d=1193161562
Since that grounding point is no longer... Can I use another firewall stud to mount the grounding strap to?
FWIW all the grounds were crap on the Burb! Between Rob and TD's posts on grounds and fuses it should be cleaned up for winter in no time at all
Thanks!
Thanks!
