Pop bottle, 3/8" fuel line 3-4 feet, 3/8" bolt less than 1/2" in length.
Drill a hold in the bottle cap and stuff the line through.
Go to your driverside fuel rail using needle nose pliers disconnect, the hose thats on the end of the fuel rail, and then slide off the clamp.
Put the 1/2" bolt into the end of the line you just removed, to keep fuel that may be in there from running out.
Take the clamp you removed earlier and slide it on the 3/8" bottle test fuel line, then take the line and slide it over the barb that you exposed by removing the return line on the end of the rail, slide the clamp down to secure the line.
Secure the bottle somewhere out of the way, and there you go, I filled a 20 oz soda bottle halfway full in 1 run so i'd recommend a run or 2 and then check your status.
