Schwind
split loyalties
I installed my boost gauge and pyro a couple of weeks ago so that I could monitor and gain knowledge of the factory setting on my truck prior to any more mods I may do. My boost with the factory vacuum system was WOT no more than 8 psi. then it would cut back. At cruise it would run between 2 and 4 psi depending on the road conditions (from flat to slight up hill runs). Tow or not. I installed a boost fooler at the beginning of this week and set it at 10 psi WOT with trailer in tow (had no real heavy loads this week). At cruise the reading is between 4 and 6 psi same road under same conditions. Today I ran my truck without the trailer and at WOT once the boost got to 10 psi or just a little above the gauge started to flutter. Not really losing boost just fluttering at around the 10 psi mark. Other than at WOT the needle is steady at what ever point on the gauge it is at. It also doesn’t flutter when I am pulling. Was just wondering if this is a sign that the PCM is trying to defuel or what? My EGT’s are not any higher than they were without the boost fooler. About 950 at the highest with trailer in tow.
I am running factory vacuum system for the wastegate and my exhaust is totally factory with cat and muffler. The boost fooler sure has awoken the beast and my throttle response has greatly improved. My top end acceleration is about twice what it was before. I like it!!! I even gave a Dmax a run for awhile today he was smiling when he finally passed me but he had a hard time doing it.
Any ideas of why it flutters and/or what I can do to get more out of it without harm would be greatly appreciated. I know this is probably old school for alot of you but its my start.
