hookedup50
Like title says. This is a never used heater and new cord. I plugged it in and it does not work. I removed the plug from heater itself and reinstalled it to no avail. It is well past warrantee and not wasting time calling Walt, as that was my first mistake. I did not know better at time. I am going to source a new plug as well as unit. Checking with Leroy first then the usual vendors. I also have interest in oil pan heater as well. Can I get by with pan heater only or should still have hot coolant. Also Ive seen coolant heaters in line on hoses. Is this a better alternative or just another place to have leaks. Thanks in advance. I get about 3 weeks of -18F mornings mid january. What is the low temp I should be plugging in at for easy starts? In the past 20 degrees would cause hard starts, but I have upgraded glow wires and battery cables from Bruce(great products). Gonna install Duratherms as I have AC delcos now. Thanks in advance.
