03WIDEMAX
BFT
Ok I need help from the throbbing brain that makes up DTR. I've owned this truck for about 9 months. This past May I had all the injectors replaced under warranty. They changed the oil and filter when they did the injectors. I just changed the oil last week and sent it in to the lab and the report came back with some of the metals high and also there is anti-freeze in the oil. I checked the recovery tank and there is black soot residue ringing the inside. The truck has 136,000 miles on it right now. What tests need to be done to find the leak? Where do I start? How often should I change the oil until I find the problem? Any help is appreciated! :cheers2:
