handcannon
I just came across some info on a different type of auxiliary fluid cooler. They can be used for: tranny, power steering, engine oil, hydraulics, etc. I've never seen anything like these before. I am wondering if anybody here has had any experience with them and knows how their efficiency compares to the stock tranny and engine oil coolers in our vehicles. They aren't cheap, but because of their apparent durability they could be installed in places on our vehicles where the stock units could be easily damaged. In my thinking the stock coolers could be removed from in front of the radiator, cutting down on heat builup in the cooling stack. In theory I'd think that this could be beneficial in towing applications. The web site where I found them is: coolcraft(dot)com
Here's their web site info.
Specialty Auto Tech dual pass coolers utilize a new dual pass internal baffling system that will increase cooling capacity by 40%. Made of sturdy welded aluminum construction, this cooler will withstand the punishment of the toughest operating systems such as flying road debris. It will contain pressure up to 3,000 PSI. They are designed to cool any vehicle fluids including:
* Automatic Transmission Fluid
* Power Steering Fluid
* Engine Oil
* Engine Coolant
* Fuel
* Street Hydraulics
The heat sink design has internal and external cooling fins to transfer heat and minimize the need for direct airflow. Compact design (3 inch diameter) mounts in tight spaces. Cools better than conventional coolers when you need it most, under 40 MPH. High fluid capacity adds ½ quart per foot of cooler length.
Available in 12 inch, 18 inch and 24 inch satin or polished finishes. All coolers come standard with ¼ inch NPT inlet/outlet. 30 inch, oil, fuel and hydraulic coolers need to be special ordered
Application Size
Stand Alone:
Under 400 HP and 3,000 LBS BVW 18" Dual Pass
Over 400 HP or 3,000 LBS BVw 24" Dual Pass
Supplemental:
Auto / Light Truck 18" Dual Pass
Light Truck / Towing 30" Dual Pass (Special order or use 2)
Note: Stall converters - ADD 6" in length of cooler per each additional 1,000 RPM in converter.
Cooling System
Small Block 24" Dual Pass
Big Block 30" Dual Pass (Special order or use 2)
Power Steering
Standard Pump 12" Dual Pass
High Flow Pump 18" Dual Pass
Engine Oil (Special Order)
Small Block 18" (3/8" NPT)
Big Block 24" (3/8" NPT)
Fuel (Special Order)
Street 12"
Street Hydraulics (Special Order)
Street 18"
Street Comp 24"
(Use one cooler per pump)
Note: The above recommendations are based on average applications. Always use the maximum cooler length for space available or a combination of two smaller lengths to achieve desired results. In towing or off-road applications use the cooler as a supplemental source only. Polished coolers are NOT as effective as satin finish coolers. Add an additional 6" in length for polished finishes.
Don
* Engine Oil
* Engine Coolant
* Fuel
* Street Hydraulics
Application Size
Stand Alone:
Supplemental:
Cooling System
Power Steering
Street 12"
Street 18"
Street Comp 24"
Don
