dka99burb
Ok. I need to focus on the current project today. I have bolted in my aux tank, acquired a inline pump that has a check valve as well as an anti-siphon valve. I also have a simple timer circuit with relay on a single board that I grabbed from ebay. I am thinking that since I have a camper shell that I want the pump on the frame rail but I have no idea where to pull the 12V from. I have a small, transparent, plastic, elec. proj. box that I will put the timer/relay board in and mount in the cab. It has a countdown display on it.. :thumbsup:
I would like opinions on where to pull my power from and where to locate the pump. It will simply be refilling the main tank thru a T in the fill tube. I am also debating what to do with the vent from the aux tank. Was thinking of tying it into the evap sys on truck but afraid of it throwing codes due to the extra volume to pull vac on.
