Chevypoor
Active Member
Looking at the s&b air intake for the new 93 6.5 turbo diesel. Anyone tried this intake with the ATT? Does it fit? The AFE unit I had did not- the preformed tube hit the battery.
When I bought the Burb it had an AFE 'cold' intake setup and the GM-8; the AFE rubbed the battery even with the GM-8. Did not bother correcting the AFE as I wanted to (and did) switch to a K47.
It worked fine for me with the GM-5, ATT and the Super 84.
Here's a few previous shots of my Heath (SB) CAI with the ATT.
Note: Using the OEM holes in the fender to secure the intake will result in a slight alignment offset at the turbo. Solution is to drill a new hole in the fender to secure the filter housing to the fender after securing the set up to the turbo. Additionally, there will be a slight gap at the fender air outlet to the filter box if you don't have the OEM ducting (easily corrected with a little innovative effort).
How's the super 84 compare to the other turbos?
