I did a couple passes with gmtdscan running today, and I want to see if the numbers make sense. They seem alright to me (although the air temp is bonkers high). The truck is a 95 3500 dually, automatic, 4.10s, F code engine. As far as mods, I have the wastegate held shut with full vacuum, minus a pinhole I added. It opens up at about 9-10psi, depending on the gear. I also have a 10kOhm resistor in the signal line from the MAP (aka boost fooler).
So heres the numbers I see
MAP shows 12.4psi at idle, which makes sense. 14.7 atmosphere, - 2.3psi or so for the boost fooler.
Calculated boost is always 1.5-2psi lower than actual boost. I'm guessing this means the ecm could be fueling more? Related to the boost fooler maybe?
IATs are bonkers. 130F driving around (its 90F outside), gets upto 260 at WOT after 5-6 seconds.
Coolant temp stays at 198-199, gets upto 205 under WOT, but drops back to 200 still at WOT. Seems like its cycling correctly, just 5-10 degrees too hot. Gauge shows 210 steady the entire time =(
I just wanted to know if these numbers are WAAAAY out there. My next issue to sort out is a boost actuator code on the highway. My truck runs 7psi at 70mph. A little too much, and it ends up setting the check engine light and defueling. On-the-fly restart fixes it for a couple minutes. I will take my laptop along next time i happen to be anywhere near an interstate.
