jhornsby3
Active Member
Hope all had a great Christmas and have a great New Years,
So here's the issues. I replaced the head gaskets on the pick up. Took some time to get up the cash as the heads were cracked(no supprise) and needed replaced. Got two heads from a shop that was new castings with good valves and all. The guy built up a 93 block and put it in his 86 pick up. Had cavitation at the front of his block and did not have it decked, Leaked coolant and broke the crank at right at 4k after build. Then he went gasser.
So I bought those heads and had a friend help me put things back together. Got the passengers side done by myself and all went together great. Tourqed the heads the stated 20, 55, then 1/4 plus. On the drivers side, with the help, got the head started down and the gasket was bent at the top where the rods go in. Took the head back off and look it over. All seemed good. Then going back on with the head he gouged the top back of the head into the gasket gouging the silver coating off the gasket from the #5 cyl to the #7 cyl. I didn't think anything of it so proceded to tourqing. Went to 20 then 55 and marked the bolts. He took them to close to the 1/4 on some and to right at the 1/4 on others. Again didn't think anything of it. Replaced all the fluids let sit over night. Now the next morning it started hard and blew white for a few minutes. Cleared up and I ran it for about 4 hours at high idle shut it down and watched things for any cooling leaks. Nothing. Got up to go to work and it started hard, like with a punch. Like crank a couple times and woomp it fires and idles rough for a few seconds. Got 25 miles and the low coolant lite comes on, toped it off and comtinued the last 35 miles. no issues. That night get in and the same start up and it steams alot. More than starting on a cold night. In traffic it steams when at a stop or slow idle down road. Got home and it was down on coolant about to bottom of bottle and no pressure in the hoses. Exhaust has the smell of the Water Wetter(amonia smell). Now I'm thinking that it needs to come back apart but I want some advice of those that are in the know before I procede.
Anybody have a clue or have seen this before.
John
John
